Hedgehog's avatar
Hedgehog
2006 Monaco Knight engine temp gauge
Did a short trip to the casino last night and noticed my engine temp gauge wasn't working properly. The temp was reading a hair above the cold line and once in a while, it would come up a little more. I monitored my coach on the Aladdin system and according to that the engine was staying between 177 and 181. The cooling system was flushed last spring and filled with Rotella ELC so it has been maintained. Do you think my temp gauge is junk? Does the Aladdin use the same water temp sensor as the gauge? Any input would be appreciated.
  • Before I would go changing the temp gauge etc. I would see if there's a short in your ignition switch or with your levelers. Fix that problem and your temp gauge might work as designed...check for a loose ground....Dennis
