Rolin wrote:
MoutainAir05 and enblethen,
I will reconsider the dremel option. I have a wire brush for the dremel.
Will look for De-Ox compound
Will get a new battery ground wire and new connectors and connect to engine battery. Just work on one problem at a time. Eating the elephant in one bit increments ;-)
The engine battery was charged and in good condition.
All batteries (House and Chassis) are just one year old.
The place for the De-ox compound is Amazon or a Electrical supply hose. This stuff is good and expensive. Unless you have a lot to do , really clean with the wire wheel. Unless you are close to the water or very high humidity, you might not need it. enblethen, not taking away from your suggestion.
