dougrainer
May 01, 2018Nomad
The Motor/Transmission has a built in clutch. When you extend or retract fully, you will hear it rachet. You STOP when you jear the first rachet. Your manual is WRONG. There are some slides you can hold for 5 to 10 seconds. YOUR specific Slide you do NOT. And yes, it could cause the gears to shear. MY question is, Did he replace JUST the defective gear? Because, the individual parts of that Powergear/LCI gear assbly are no longer available, you MUST replace the complete motor/transmission and the BAD gear as a unit. That is how Tiffin sells the replacement part. This is just part of what your system looks like. Doug
https://store.lci1.com/18-1-motors-driveshaft-single-afss
