tiffy2000
May 15, 2018Explorer
from a power gear manual
YOUR SLIDE-OUT CONTROLLER
The slide-out control unit for your slide-out system is located near the motor assembly.
This unit is controlled by the switch panel located in the main living area. It activates
both the motor and the slide-out alarm when the switch panel is operated. It also limits
the amount of power the drive motor can draw, shutting off the system when the motor
load exceeds the control’s setting.
CAUTION:
This control has an adjustment that allows for a wide range of power
settings. If this adjustment is set too high, damage to the room seal flanges can result.
Please note the adjusting screw’s normal setting, and do not exceed the maximum setting
CAUTION:
