j-d
Feb 09, 2016Explorer II
You should be able to monitor the positioning of the Max A/C aka Recirculate Door by crouching outside the passenger door and looking up/into the foot well while somebody changes modes to/from Max with the engine running. It's the silver "can" with the black "top" that has the white tube attached. Middle of page 3 in the BAT thread. You should be able to see its arm extend and retract as you or a helper changes modes.
But you get colder air in Normal than in Max. What I wonder now, is what happens when you select MAX. To my understanding three things should happen:
1. Power to Compressor Clutch
2. Recirc Door to Recirc (inside air)
3. Blend Door totally blocks air flow past Heater Core
The Blend Door shows at the bottom of the vacuum hose diagram. Notice that there's a dotted line from the Knob to the Door. NO vacuum line or actuator. That's because it's electrically controlled. Position of the Knob tells a little motor/gearbox, mounted somewhere on the HVAC cabinet, where to position the Blend Door.
Open the hood, look at the compressor clutch, and make sure it's engaged (the front of it spinning) in Normal, Max, and Defrost. Should NOT engage in Off and Vent.
So... Look at the Recirc Door (but I no longer think it's your problem), and Look at the Compressor Clutch. If the Clutch STAYS engaged in MAX, then suspicion points to Blend Door.
