haste maker wrote:
Doug..I didn't find a wiper control module in my unit, I checked with a Ford dealer & they said it was an Allergo item, so I called Tiffin & was told by the service dept. that my unit didn't have wiper control module ? I have replaced the switch & checked all the fuses...all were good...I also ran a hot wire from the battery to the motor & it ran....Thanks for your help.
Is your switch mounted in the dash front or on the Turn signal? If Dash, does it have the center knob for OFF and Wiper speeds and the outer ring for the timing of the Intermittant? Doug
