bullydogs1
Dec 03, 2014Explorer II
Sounds like either, your transfer switch is not powering a leg on shore power..OR your 50 amp cord has a bad plug end or the cord itself could not be carrying a leg...you need to check that cord where it comes into the transfer switch or the end of the cord and one of those plug heads might be bad....if you have one of those cords that attach at the motorhome and the shore post..try a different cord if you can find one...if still same problem, then it is definitely transfer switch....or even the connection at the motorhome end where you plug in the cord.
