Mich_F
Jul 23, 2016Explorer
dadcalkins wrote:
Y-Guy
That is very close to my damaged area. I was thinking it could be a antenna for the house stereo.
Did you fix it yourself?
If so did you do it all from the roof or did you have to pull the microwave out?
Assuming what you have is a base for an antenna, and another antenna can't be screwed back on the base, clean the caulking/sealant off the base and remove the screws securing the base to the roof. Just unthread the antenna lead from the base and install a new base and antenna.
If the stereo works fine the way it is, you might not need to replace the antenna mast.
38,763 PostsLatest Activity: Dec 05, 2025
