Ivylog
May 15, 2013Explorer III
The basement heat is on it's own adjustable Tstat in the basement and often set at a higher temp (40) than necesary. Hopefully it's only the solution in the above post... the breaker but not even the fan will work if it's tripped/defective. Lower the temp on #3 and see if it will cool with the other two turned off. With a 10K you should be able to run all three at one time. If you have two zones in one Tstat then make sure both are set the same: cool & fans both on auto.
