halfdoc's avatar
halfdoc
2008 Bounder F/G/B indicator panel problem.
2008 Bounder 34G on workhorse chassis.
I am trying to troubleshoot a problem with the touchsensor panel indicator for fresh, grey, black tank as well as main/aux battery. I
Recently only the aux battery will display. Nothing with tank indicator will light up and nothing displays with main battery. I have checked behind the panel and it looks ok (nothing obvious). I do not see an inline fuse as it disappears into the dash wiring. I have checked all of the fuses in the hidden panel left side of dash. I have checked all of the fuses in the engine compartment. I have checked all of the fuses in the propane compartment. I have checked all of the breakers and fuses in the bedroom.
I am not good with a multi-meter but the panel is getting voltage from the aux battery.
I am posting hoping for some other ideas before I hire help. Very hard to search for trouble with the panel... tons of info on trouble with sensors.
Panel on the right of the first picture.
https://www.dropbox.com/s/n64esfe7wk81njv/IMG_0113.jpg?dl=0
https://www.dropbox.com/s/4wjmewebyn97b6v/IMG_0111.jpg?dl=0
Thanks!
David
1 Reply
  • I would be checking that the connections of both ends of your battery cables are clean and tight. I would also see if the panel lights change when you push the dashboard "Boost" switch. You may be having an issue with your house batteries nearing the end of their life.
