time2roll
Nov 10, 2014Nomad
ScottG wrote:
Use any synthetic oil that's rated for both.
FWIW, it will do no harm to put additive in a non-LSD diff.
+1 the fluid is not that different is it? Just use the heavier stuff and you are fine.
2008 OEM LS has enough wear that it probably barely works and will not chatter or need the friction modifier additive.
