Red_Racer
Jul 30, 2014Explorer
Guys,
Thanks for the comments so far. Matt's note on replacing the meter in the panel is an interesting one. I actually think it is working just fine, though it is not measuring the voltage at the batteries but instead from somewhere inside the BCC. Probably off of one of the solenoids or maybe from a spot on the circuit board.
That is what tripped me up in the first place. If the meter in the panel says all is good, and it is not all good (my case) what do you believe? I'll fix the grounding issue this weekend and post back if that fixed it. If it doesn't fix it, then I hope you all have suggestions!!
RR
RR
38,707 PostsLatest Activity: Feb 18, 2025
