j-d
Jul 08, 2016Explorer II
tobydad wrote:
Usually the breakers are located in the converter. Open the panel and you should see the 12 volt fuses and the circuit breaker switches.
If the question is "Where's the Panel?" Sometimes the "Load Center" (All in One Converter, Charger, Breaker Panel and Fuse Panel) is on the side of the bed base. If you've got a blanket or such hanging over the side or end, you may not see the Center.
38,766 PostsLatest Activity: Jan 10, 2026
