cgmartine
Jul 09, 2016Explorer
Send me a PM and I will try to copy the instruction brochure for operation of the Powergear slides, but basically, you locate the slideout motor.
1. It will be either ahead of the front rail or behind the back rail.
2. Locate the two-pin connector on the slideout motor and disconnect it.
3. Rotate the lever on the backside of the motor counter-clockwise about 1/8th turn (looking from the rear of the motor). This will release the brake that holds the room in place. The room is now free to move. Using a 3/4 wrench or ratchet, crank the room, either in or out (depending on your needs, using the manual override.)
I hope this helps.
I hope this helps.
38,766 PostsLatest Activity: Jan 10, 2026
