OldRadios
Jan 26, 2014Explorer
I would also suspect something else. I don't think they share a fuel pump since the generator won't drain the tank. I think it stops at about 1/4 tank. Bad fuel? Maybe water in the tank? It would have to be a lot of water though since the gen won't run either.
Do you have less than a 1/4 tank of gas? That would be why the gen won't run. Maybe a combination of that and a bad fuel pump, clogged fuel filter, or water in the tank if the tank is really low.
My old B would quit on hills if the fuel filter was nearly clogged. It was a really old gas tank though and I suspect it was full of crud.
38,766 PostsLatest Activity: Jan 10, 2026
