DamonOwner
Mar 25, 2016Explorer
2008 Windsport owners please step in here...
I have a 2008 Windsport that has 4 round headlights. Each headlight has a bulb that supports high and low beam.
When I turn the headlights on only the outermost light on each side turns on. When I turn on the high beam, the outer lights turn off and the other set turns on.
Given that the headlights are only 5 3/4" headlights and smaller than most headlights, the light output on low beams is pathetic at best. I will spend some time checking out the voltage at the light and see if an upgrade to the harness is warranted.
However, my question to the board and other 2008 Windsport owners in particular is: "Do your lights operate this way as well?"
