SweetWaterSurpr
Aug 07, 2015Explorer
New owner here
So I'm obviously new here. Just picked up a 4X4 2009 Phoenix Cruiser. Been reading a lot of topics and getting tons of info. I'll be trying to learn as much as possible.
snowdance wrote:
On the road TP can be worked out by getting a loaded as you run it weight on each axle or wheel if you like. You can then look up the TP for that weight on a tire company chart. You can find them on most major tire company sites.
You are right you will have to really watch the rear tires when you lower the pressure. But I would think you will find a tire pressure that works. Remember you have two rear tires on each side so have a larger area and will not need to drop the pressure as much as the front..
pnichols wrote:
Outstanding rig ... way to go!!
The chassis is right ... a rugged over-kill 4X4 V10 E450. The length is right ... kinda short. The quality is right ... PC builds pretty good stuff. The pedigree is right ... good old American gas powered iron.
IMHO, you've found "the perfect RV". Now go and show those TC owners that you have a Class C that can do it too, but with way more comfort when you do it.
Have fun, and keep us posted on your adventures.
