Mike_NWExplorerDec 29, 20192009 Tiffin Allegro Bay Water Heater Check ValveWe have a 2009 Tiffin Allegro Bay 37 QDB and I need to replace the check valve on the hot water heater. It looks like the only access to this valve would be to remove the water tank from the outside...Show More
enblethenNomadDec 29, 2019Most of the original check valves are plastic. You should be able to find one made out of brass.
Related Content2012 ALLEGRO TIFFINtiffin allegroTest drove 2017 Tiffin AllegroTiffin Allegro Bus ShocksTiffin Allegro Open Road 36LA Build
