rondeb
Aug 02, 2011Explorer
I got them both at Home Dept. I thought they both really fit well. On the bathroom one, you will have to use a plug unless you want to use the soap dispenser. Using all 3 just really crammed it together, so We didn't use it and put the plug in. You do have to have a 1 1/4 hole drill to install the lever handle in the bath. We used a wooden dowel held in the old hole to give the hole saw something to grab to make the hole. DH cut the plug top off and just caulked it on as the center hole is not cut out.
Moen Kitchen Faucet
It is a rather small one which really fits well with the sink.
Pegasus Bath Faucet
The water filter is just a standard Culligan RV unit. The only difference between an RV Culligan and a standard one that you can buy is that the RV one has a winterization plug that fits on when you winterize or sanitize so you don't ruin your filter. We use level II filters which gives you great tasting water and fairly good pressure.
Moen Kitchen Faucet
Pegasus Bath Faucet
38,780 PostsLatest Activity: Aug 05, 2026
