rondeb
Oct 04, 2011Explorer
Unless you want to run your furnace which will keep your water lines and tanks from freezing, I would not suggest it. If you keep your furnace on very low, you can use a 100 watt light bulb in the water inlet compartment and then keep a heating pad on low over the water pump area. You might get away with it and then drain your fresh water tank and keep your gray and black drained. A space heater would not keep your water lines from freezing.
