Goldencrazy
Nov 07, 2011Explorer
Deb, Aqua hot is usually a heating and hot water system often found in large DP's. You have motoraid which heats your hot water as you travel. It is totally an extension of your engine cooling system and so already has anti-freeze. So all you need do is to turn the hot water bypass and then drain the hot water tank which I think is an Atwood with the plastic plug not the anode rod. Then open the low point drains and the tank drain to let water drain. Finally use the tube in the water tank compartment to distribute the pink stuff throughout using the pump. Don't forget to press the release on water intake and also run pink stuff through the outside shower head. Pour a little in the traps and you are done. It took me about 15 minutes and two gallons so I have no problem winterizing in between use when I am in WI and it is getting to mid 20's at night.
38,780 PostsLatest Activity: Jul 04, 2015
