rondeb
Nov 09, 2011Explorer
Goldencrazy wrote:
Yes, on your in dash radio/dvd player select AUX 1. Your TV should play through it. Then if you wish you can go to audio on the tv menu and select speakers off and total control is with the radio and the surround speakers. At least that is the way it operates on my Vista. I just went out to make sure. You can then choose which speakers you wish to employ by selecting A,B, C in any combo you wish as you know. The Kelderman parts arrived today. Very quick. Install early next week. I have a question. When you used a light bulb to add heat to the water tank last winter, what size and where did you put it and on what type socket?
OK, Ron said that he used a standard plastic drop light with a 75 or 100 watt bulb (he doesn't remember- and can't find it) He isn't quite sure where he put it in the C, will need to find it just in case. Also, we bought an oversized heating pad and put it on low and placed it over the water pump and that area. The water pump is the only thing that actually had a problem. Once we put the heating pad on it, it never had another problem.
Oh, also, thanks for the info on the surround system. Works like a charm. We had tried lots of things, but couldn't get it to work.
