tinkerer
Sep 10, 2016Explorer
I can't stress enough that make sure all battery connections and cables are clean and in good shape. that has happened to me a few time when I thought i had major problems when I found a bad battery cable or connection. When testing never use the chassis for your ground. Use the battery cable and by doing this you can detect a bad ground connection. I learned all of the above the hard way.:D
