- Yes looks to be discontinued.
If you want to use the existing remote and everything connect the same I would contact WFCO to see if the 5110R would be compatible. It is rated 1000 watts but assuming your loads are light and the 12v connection has a fuse all the existing connections should work. Need to verify you have the physical space including room for cooling air flow.
https://wfcoelectronics.com/product/wf-5110r/ - LwiddisNomad IIIIs your inverter working? If so, why replace?
