J-Rooster
Jul 20, 2013Explorer
I own a 04 36' Adventurer and I had to do the opposite of what you did on tire pressure! Lower tire pressure was causing too much flex (Michelin on there website calls it tire squirm) and it was causing me handling problems while driving. If anyone doesn't understand this the tires have a slight bulge in them. And lower tire pressure causes more heat build up in a tire according to Michelins tire website. I'm glad it works for you! I was running 85 lbs. in the rear my tire shop had me change tire pressure to 100 lbs. all around and that really worked for my coach. Good Luck with your tire pressures.
38,783 PostsLatest Activity: Sep 24, 2026
