luvlabs
Jul 20, 2013Explorer
Your tire pressures should be adjusted to your wheel weights (ideally) or at least your axle weights. Get your coach on a truck scale at least get your axle weights. Use the tire charts from your tire maker to get the correct inflation pressure, add 5% for side to side variance and go with that pressure.
Handlling in cross winds isn't easy for any motorhome unless you have a tag axle coach. Suspension upgrades may or may not help. Improper tire pressures will certainly not help handling and it easy to check and correct.
38,783 PostsLatest Activity: Sep 23, 2026
