Arizona_Kid
Aug 13, 2013Explorer
It depends on if you have been driving the van or if its been sitting. If driving, it gets very hot, it is a big metal can, so it takes quite awhile for the van to cool down. 10 degrees is probably about as good as you can do at that point. It will help if you can park in the shade, hose down underneath of the chassis, and open the hood. 15 to 20 degrees below the ambient temp is probably about the best you will get under ideal conditions.
I couldn't even use my Rt here in AZ in the summer, had to seek cooler climates.
I doubt there is anything wrong with the A/C.
The Reflectix that was referenced does help.
38,782 PostsLatest Activity: Aug 30, 2026
