cavie wrote:
leggy wrote:
Our unit is 3 yrs old and I just had an HVAC guy look at it. Domestic brand. He had to add a bunch of refrigerant. Had to add a piece to be able to do it. Much cooler now and no freezing up anymore.
Did he FIX the leak the Gas leaked out of?? If not it's gonna HAPPEN AGAIN.
What's a "bunch" of Coolant? They only hold 1 lb. Doug- HappytravelerExplorerWe have a 35ft. motorhome with ducted air and we replaced a ceiling vent fan with a Atwood Air Command 13,500 BTU non-ducted Air Conditioner. We spend a lot of time in Palm Desert and the River. It makes a huge difference having both airs running.
- cavieExplorer
Did he FIX the leak the Gas leaked out of?? If not it's gonna HAPPEN AGAIN. - accsysExplorerIs rhe rear of your unit much cooler than the front? That is normally the situation in our coach and we found out when we were in 100+ in Redding, CA that placing a 20" box fan in the doorway of the bedroom blowing towards the front pulled that cool air towards the front sufficiently for us to be comfortable -very cheap temporary fix for a temporary problem.
- wa8yxmExplorer III
Grey Mountain wrote:
We are experiencing tripld digit/high 90s heat. Although the controls are set on 68 or so, the coach will no cool down below around 82. Any ideas on a solution?
GM
Just two
one is shade. Frankly when the outside is high 90's with sun the Roof top A/C won't keep up
I am not suggesting more A/C cause you will hit the power limit of your site (though a small portable (Ducted) in the bedroom might help)
Tahquamenon falls State Park. Look it up. Should be cooler there. - Grey_MountainExplorer
jjrbus wrote:
I have seen perfectly good roof air replaced because the evaporator was plugged with crud.
Google cleaning RV roof air evaporator or coils.
OK. Thanks.
GM - jjrbusExplorerI have seen perfectly good roof air replaced because the evaporator was plugged with crud.
Google cleaning RV roof air evaporator or coils. - Grey_MountainExplorerThanks for all the information. Not a technician, so may leave all that for the fixit shop when we get home. We are in Gretna, Nebraska for a week, temps expected to be in the 80s, so I may not have a continuing problem.
GM - leggyExplorerOur unit is 3 yrs old and I just had an HVAC guy look at it. Domestic brand. He had to add a bunch of refrigerant. Had to add a piece to be able to do it. Much cooler now and no freezing up anymore.
- craig7hNomad IITo help with the cooling I went and made Styrofoam inserts for all of the roof vents. There is a lot of sunlight and heat that comes through those exhaust vents. That seemed to help a lot. Also get some type of reflective material and put in the windshield. That windshield is like a heat producing machine. Like said before about the 20deg. difference is true. However if you feel the need to get up and clean off the condenser fins. Be carefully not to bend the fins, use good but not strong water pressure and a very soft brush. If you have a lot of bent fins that need to be straighten go to a plumbing supply shop and ask for a "fin comb" its a tool made to straighten the fins.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 08, 2026
