craig7h
Aug 21, 2019Nomad II
To help with the cooling I went and made Styrofoam inserts for all of the roof vents. There is a lot of sunlight and heat that comes through those exhaust vents. That seemed to help a lot. Also get some type of reflective material and put in the windshield. That windshield is like a heat producing machine. Like said before about the 20deg. difference is true. However if you feel the need to get up and clean off the condenser fins. Be carefully not to bend the fins, use good but not strong water pressure and a very soft brush. If you have a lot of bent fins that need to be straighten go to a plumbing supply shop and ask for a "fin comb" its a tool made to straighten the fins.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
