- EYEMLOSTExplorer
RKW wrote:
For a certain part of a niche market, namely those with small RVs and a penchant for boondocking, this trend is a game changer. I'm looking forward to how this develops.
It's awesome the article listed a wall-mounted one.
A very possible near future option.:C - RKWExplorer IIFor a certain part of a niche market, namely those with small RVs and a penchant for boondocking, this trend is a game changer. I'm looking forward to how this develops.
- 3_tonsExplorer IIIThe amps are low, but at a meager 6824 btu’s so is the output, meaning it might be a bit marginal in campers with slide-outs, and snaking #2AWG wires (or larger) up to the roof could be a bit problematic for some, though is also available in 24v…Still, a most interesting proposition due the uber efficient what’s apparently a variable speed inverter compressor…Hopefully a sign of more things to come, opening up the possibility of true solar sustaining cooling!
3 tons - Buzzcut1Nomad IIas for the 9200. I have a Lance 1055 its the largest non slide camper lance ever made. I have been out near Vegas when it was 113* and the Polar cub 9200 AC kept us in the Low 70s which is just fine by me and that all I need to run it is a Honda 2000 is another bonus.
- JRscoobyExplorer IIThis is the first time I have read a article directed to RVers that used a fraise like "many truckers use".
Many of them have spent a lot of time using 12V to make life better. - pianotunaNomad IIIKeytag,
I was invited to write a series of articles on Solar. My reward was the pleasure and being asked to do so.
The article is flawed and could be improved. But it is no less valuable. I've not looked at AC units for some time and to find another couple of DC units is worthwhile.
I do question the swamp cooler. It seems quite pricey for what it is. But then, growing up a bottle of coke was only a dime (or 5 cents at a school dance) makes me frugal. - adamisNomad IIKayteg1 you are being a bit overly negative on the value of this article. Of the 5 units listed, I only was aware of just 2. The other three were options I had no knowledge about and actually find to be very interesting. Sure, it wasn't an in the weeds article that one could geek out on the numbers but I don't think that was the point. Unless you are willing to do the legwork yourself to get the level of detail you want, don't knock others for the effort they put in themselves. Any information is much better than no information.
Also, your first hand experience with the amperage draw though a valuable insight doesn't make the article wrong. Possibly what is happening here is the amperage draw being reported is the starting amperage and that is always higher than the running amperage. Manufacturers have to rate their equipment on what it draws to get it running so it is going to be higher. - pianotunaNomad III
c.traveler2 wrote:
Are you using those Sio2 batteries yet, looks interesting.
valhalla360 suggested the chart.
With covid preventing me from picking them up--and income in a nose dive for the same reason, I'm going to wait a year. I may do massive solar first as well. - adamisNomad IIThe Dometic Coolaire 2000RTX really looks like the best solution for Truck Campers and will be at the top of my list...
"19.5 amps DC in the Eco mode and 29 amps DC maximum"!!!
https://www.nomadiccooling.com/product-page/dometic-coolair-2000-rtx-12v
That is incredible! Sure, it may not keep up in 120F weather but 100F weather looks like it will be just fine and that is what we experience 99% of the time. Couple this with some good solar and some nice LiFePo4 batteries and you are set for most situations.
Granted the expense of $2800 is a lot more than the RecPro or the Coleman Mach 8 but I think the performance is worth the cost for my personal needs.
