adamis
Aug 03, 2021Nomad II
Kayteg1 you are being a bit overly negative on the value of this article. Of the 5 units listed, I only was aware of just 2. The other three were options I had no knowledge about and actually find to be very interesting. Sure, it wasn't an in the weeds article that one could geek out on the numbers but I don't think that was the point. Unless you are willing to do the legwork yourself to get the level of detail you want, don't knock others for the effort they put in themselves. Any information is much better than no information.
Also, your first hand experience with the amperage draw though a valuable insight doesn't make the article wrong. Possibly what is happening here is the amperage draw being reported is the starting amperage and that is always higher than the running amperage. Manufacturers have to rate their equipment on what it draws to get it running so it is going to be higher.
