3_tons
Aug 04, 2021Explorer III
The amps are low, but at a meager 6824 btu’s so is the output, meaning it might be a bit marginal in campers with slide-outs, and snaking #2AWG wires (or larger) up to the roof could be a bit problematic for some, though is also available in 24v…Still, a most interesting proposition due the uber efficient what’s apparently a variable speed inverter compressor…Hopefully a sign of more things to come, opening up the possibility of true solar sustaining cooling!
3 tons
3 tons
