Arizona_Kid
Sep 19, 2013Explorer
You can always run the A/C using the generator, while driving. Also, Fantastic Fans recommends keeping the vent fan all the way open while driving.
"Recommendations: You may use your Fan-Tastic Vent while driving or in windy conditions. In this case keep your dome fully open. Keep your fingers away from the knob while dome is automatically opening or closing unless you deliberately intend
to apply opposite force to stop dome partially open. When storing your Motorhome, lower your dome until it is completely closed and turn the 3 speed knob to O-Off.
NOTE: At 1/3 dome open, exhaust efficiency is reduced to 90%.
NOTE: Fan-Tastic Vent does not recommend placing a vent cover over, or using a foam filter on your Fan-Tastic Vent. This greatly restricts airflow, causing accumulation of dust and increased sound levels."
38,782 PostsLatest Activity: Aug 30, 2026
