RLS7201
Apr 28, 2015Explorer II
Check the toe-in first. It's quick and easy. Can be done with a tape measure, two straight pins and two people. Stick the straight pins in the center rib of the tires, with the pins being 90° from the ground, and measure the distance between the two. Rotate the tires 180° and measure again. The difference between the two measurements is the toe-in or toe-out. You want the front measurement to be the lesser of the two. I suggest 5/23 toe-in.
Tape measures do not get out of calibration. All the fancy lazer and mirror alignment equipment can be out of calibration.
Richard
Richard
38,763 PostsLatest Activity: Dec 25, 2025
