DrewE
Jun 01, 2016Explorer II
Besides the water heater bypass, verify that you have turned off the taps for the outside shower and not merely shut off the valve on the shower head (or in its hose). If the taps are open but the shower head valve shut, the shower is off but the hot and cold water lines are connected together, which tends to lead to unpredictable hot water performance, much like if the water heater bypass is improperly set.
Chances are very, very good your problem is either this or the water heater bypass as Old-Biscuit suggested.
38,763 PostsLatest Activity: Dec 05, 2025
