Kmaines
Jun 19, 2016Explorer
I drained the tank and disconnected the hot water line from the tank. Then I blew air in the hot water line and it blew the water out the sink faucet, no blockage there. Then I blew air into the tank and it was free flowing, no check valve or blockage. I hookef it back up and filled the tank and opened the hot water valve. Then I opened the bypass valve and got water out of the hot water tap. I turned the bypass valve off and the water stops from the hot water tap. Uuuggghhh, I don't understand. Am I missing something obvious? I also took the check valve out but it was not a check valve, it was just a hollow brass fitting. Is there an internal mechanism in these tanks that would stop water from flowing out? I felt inside the tank and there was no obstruction. Tia
38,763 PostsLatest Activity: Dec 05, 2025
