mrbobccExplorerMay 28, 20142014 Phaeton 42' LH voltage dropWe have a 2014 Tiffin 42"LH Phaeton. When plugged into shore power you turn the key on and the lights dim a little and I lose 3 volts AC at the outlets. I am told that when you turn on the key the i...Show More
CA_TravelerExplorer IIIMay 28, 2014You probably have a inverter/charger that stops charging when the inverter is on hence the DC voltage drop.
Related ContentTowing 2014 Voltage 39052013 vs 2014 voltage2009 Tiffin Phaeton Engine RebuildPhaeton MotorhomeLow Battery Voltage
