mrbobccExplorerMay 28, 20142014 Phaeton 42' LH voltage dropWe have a 2014 Tiffin 42"LH Phaeton. When plugged into shore power you turn the key on and the lights dim a little and I lose 3 volts AC at the outlets. I am told that when you turn on the key the i...Show More
dougrainerNomadMay 29, 2014Verify the battery water is correct and that the battery cables are tight. Doug
Related ContentTowing 2014 Voltage 39052013 vs 2014 voltage2009 Tiffin Phaeton Engine RebuildPhaeton MotorhomeLow Battery Voltage
