mrbobcc
May 29, 2014Explorer
Just talked to Tiffin, their best guess is a loose connection between the shore power and the inverter. That is a lot of wire to check...... It has a Magnum MS Series Inverter 2000 watt. When I disconnect shore power I need to turn the inverter on manually. Will be collecting voltages reading to post. It is going in going in for service next Mon but I have not had the best of luck with them. Like the blue tooth mic just below the air tanks gauge that does not work I was told that was a speaker for alarms like low air, etc.... This is the forth time it is going back to refix things that were said to have been fixed. So I learn more here then else where. If you do not do your homework don't cry when something does not work. I really thank you guys for the input I am getting here on where to look.
38,767 PostsLatest Activity: Jun 02, 2013
