- moishehExplorerGreat news. The reviews of the new truck have been very positive. I might wait for the diesel.
Moisheh - DSDP_DonExplorerIf anyone looks for the "N" on the transfer switch dial, look very closely. As was stated, it's a clear "N", not painted like the "2H" and "4H". It will only illuminate when you hold the dial to the right for a few seconds. After I bought my Silverado, I panicked because I couldn't see the "N", even though I checked the owner's manual before purchase. I finally looked really close and saw it.
- J-RoosterExplorer
DSDP Don wrote:
X-2, And the Colorado is Chey's truck of the year!
Yes....The 2015 4x4 is flat towable. I think Roadmaster finished up tow bar brackets last week. - whporwilExplorerI got a new Canyon last Friday. Only the 4x4 can be flat towed and according to my book all you have to do is disconnect the negative battery connection. My manual did have a supplement loose page for flat towing. If you look at them closely the 4x4 option is quite expensive. On the straight Canyon it's 9 grand, on mine an SLT it's about 6 grand more. And for $38,000.00 you can't get a CD player. Blue Ox does have the base kit now, Roadmaster didn't list it on there web site yesterday.
You have to look closely to see the N on the transfer switch. It's very hard to see located behind the steering wheel. All in all I really like everything about this truck. - kjburnsExplorerI did a little searching of dealer inventories and found a close shot of the transfer case dial. It looks like it has 2WD, Auto, 4 high, 4 low and N as the last setting. All but the "N" are printed in white. The "N" appears that it might light up when selected, so it's a bit hard to see otherwise. Based on this, I think they are towable.
- moishehExplorerThis subject came up in the toad forum and the conclusion was that the manual says it can be towed if it has a neutral position on the switch for the transfer case. BUT it was reported that the units in the showroom did not have the neutral position. That would be a real shame!
Moisheh - DSDP_DonExplorerYes....The 2015 4x4 is flat towable. I think Roadmaster finished up tow bar brackets last week.
- rv2goExplorer III have not seen a 2015 towing guide. Best go by a dealership and look at the owners manual.
This is Clipped from a 2014 Towing guided and it appears that they are towable.
"2015 General Motors Vehicles
This is the first year we can recall that we’re reporting on next year’s vehicles even as the current year has been introduced, but GM has already released details on many of its 2015 models. Obviously we don’t have all the info at this point, but GM is claiming that its 2015 Chevy Colorado/GMC Canyon mid- size pick-ups and full-size Tahoe/Suburban and GMC Yukon/Yukon XL 4WD models are towable." - HD8100AExplorerHaven't fully looked at the specifications of the 2015 but we have the 2010 4WD and it can be flat towed with no changes required. The 4WD comes standard with a electronic drive shaft disconnect. In 2010 only the 4WD was flat towable I assume this would be the same case for 2015. Takes about 20 seconds to disconnect the drive shaft just hold down the 2W and 4W high buttons for 10 seconds. In 2010 there is no steering wheel lock, so no fuse to remove. Very simple to set-up to tow.
38,782 PostsLatest Activity: Sep 02, 2026
