janstey58's avatar
janstey58
2015 Freightliner low antifreeze sensor
Hi All, We have a 2015 Fleetwood Discovery with the subject chassis and ISL9 engine. I currently have a low coolant dash alarm and was wonder where the sensor for this is located in the cooling system. My overflow tank is practically empty, so I am guessing the sensor is located there, and I just need to top off ATF there? Also, I am reading that I must use Extended Life Coolant (ELC) that meets Cummings specs. Other than FleetGuard are there other off the shelf ATFs that you can purchase that meet the Cummins Spec? Thx, Jeff
