Bobbo
Feb 09, 2015Explorer III
Winnebago only has the converter/charger charge the chassis battery on their Class A RV's. They do it by installing a Trik-L-Start. After ruining my chassis battery on my Winnebago by running it down a few times, I installed my own Trik-L-Start. That was 4 or 5 years ago. I have had no problems since. Highly recommended addition.
Find the relay that connects the two battery banks together when you press the AUX START button. The Trik-L-Start has 3 wires. Put one wire on one side of the relay. Put the other wire on the other side of the relay. Connect the third wire to vehicle ground, and you are done. Your chassis battery will never go down again.
