MasterElectrici
Apr 26, 2015Explorer
For all you folks with chassis battery charging problems. No cost easy fix. Take a medium nylon tywrap. Leaving the head on, cut the tywrap so it is 1.5 inches long. Take the trimmed side and put it in a vise (about 1/4 inch) and squeeze it down so it becomes thin. Depress battery boost switch and depress and hold. Insert tapered end of tywrap on left side of switch to hold it on. Converter will now keep coach batteries, and chassis batteries all charged. Remove when on the road or not using converter/charger. Battery boost relay is rated for continuous energized state. FORGET all these other add on gimmicks.
38,783 PostsLatest Activity: Sep 23, 2026
