carringb
Aug 18, 2016Explorer
X2 on making sure other electrical is off, such as electric water heating. I had a mystery draw that turned out to be a water hot pot that had been accidentally switched on!
30 amp circuit should run that just fine. I actually run my A/C off a 15amp circuit no problem. If 30 won't start it, you should monitor voltage in the coach when it tries to start, and see if its dropping below 110 volts during startup.
38,769 PostsLatest Activity: Jun 25, 2013
