dougrainer
Mar 26, 2019Nomad
You need to state what type slide if you can find out. Slides are not all the same. From your description and operation it may be a Schwintek slide room. Your description points to a normal operation for a Schwintek. IF trying to extend and nothing happens, but you then push retract and you hear see the room tighten up and then you push extend and it goes out, that is normal for a schwintek as it sometimes "loses" its memory on when it last operated--extend or retract. To get an answer to your question requires which brand/model of your slide room. Doug
38,766 PostsLatest Activity: Jan 10, 2026
