1FastSS wrote:
Well, it's in the driveway. All is good so far. It was hard for me to let the MaxLITE TT go, Had a good 12+ years and I knew how to fix everything.
Finally - Do you all run with 80psi in your tires all the time?
Thanks in advance
I adjust the tire pressure in our rig based on the weight I'm carrying, and the recommended pressures by the tire manufacturer. A little less pressure when going only for a week or so (less stuff), more pressure when I'm carrying more stuff for longer trips. Too much pressure generally means a harsher ride, to little pressure can cause the tires to overheat and possibly fail.
Good luck with your new rig.
