BeaverCamper's avatar
BeaverCamper
2018 Thor ACE 27.2 electric fridge-Go Power inverter
We have a 2018 Thor ACE 27.2 that came with an electric fridge.
We only were able to use it once before shutting down for winter.
We were getting it out and ready for use when I noticed the light in the refrigerator was not on and it did not sound like it was on.
As I recall it will run off the batteries by use of the Go Power Inverter Remote.
The Inverter status light is not on.
Now I will admit having only used this RV once I do not remember all the nuances.
Can someone with the same rig tell me if the fridge will run once I turn the main power on or is the Inverter light supposed to be on as well. Maybe I am missing a step somewhere.
I did check all the breakers and fuses and they are all good in the main panel.
Thanks!
  • i think you mean those are 100 AMP circuit breakers
    breakers are rated in Amps Not Watts
  • I just purchased a new unit of the same make. I saw the breakers on the side of the compartment above the battery. Both were 100W breaker and resetting did nothing. Was the breaker bind the batterys? If so that is a lousy location. Did the light on the remote come on after you rest? The light was working when we test drove the unit and at the PDI, but now does not come on. T=Dealer is ordering a new remote swith.
    Thanks
  • sounds like that is a DC breaker, between the batteries and inverter
  • Sorry it took so long to get back to all of you but I was out of town. Turns out the breaker was tripped for the inverter. However the breaker was not in the fuse box/breaker box. You had to go outside to near the front of the RV, into the battery compartment, reach around the battery and flip a breaker mounted on the compartment wall.
    Took the RV repair place over an hour to find it:)
  • Can you get to the inverter? Check for 12vdc in and 120vac out. Yes the inverter needs to be on to make 120v power for the fridge.
  • You may get better help at www.thorforums.com
    My ACE does not have the house style frig. so can not help.
  • Yes batteries are very good. All other electrical items work and batteries check out at over 13V.
  • Are your batteries good? Refrig should run once plugged in but you may have destroyed your batteries. Did you use the salesman switch and put a charger on the batteries? Checked the water levels in the batteries?
