We had a 2009 Navion on a 2008 Sprinter chassis. I never had any problems with the chassis battery. As a matter of fact when I sold it last year, it had the original battery. Every year I would take it out an load test it and periodically connect a Battery Minder, the one that de-sulfates the battery.
I did have excessive parasitic draws on the coach battery on the 2009 that I addressed by rewiring the radio to function more like a car radio so that when it was off, it only drew a few milliAmps. The way Winnebago wired it, it was always in standby mode using as much as 200 milliAmps. The speaker switch operated a relay and if left in the wrong position, that relay was another vampire. The speaker switch became the power switch for the radio and the relay was connected to the radio lead marked "Antenna". When the radio was switched on, the relay was energized and the coach speakers were switch from the dash radio to the coach radio. The assumption was if I turned on the coach radio, I would want the speakers connected, so it became automatic. The new Navion has no shared speaker setup. There are all sorts of ways you can mitigate unnecessary battery power consumption. There is what I consider too much vampire stuff going on in the new Navion. One obvious thing is the electric propane gas switch on the tank. Because the tank is mounted out of reach, the main cutoff is operated by switches in two locations, both of which have to be "on" or no gas flows. I discovered on one of my many trips under the RV to repair stuff that the control valve gets quite warm to the touch. The fix for that is to turn off the gas when it is not being used. There are other vampires in the system and I will get to those in due time. That is if I don't divest myself of this headache on wheels.
There is a quick disconnect for the negative ground cable adjacent to the accelerator pedal. Everyone who owns a Sprinter should know it's function and location. In an emergency, this is the only way to quickly disconnect the battery to possibly prevent a fire or serious damage. It is also recommended that if the Sprinter is not driven in three or more weeks, the battery should be disconnected. My battery is going dead in about a week's time. To isolated where the excessive current draw was coming from I first disconnected the cables attached to the positive clamp/bus and measured the resistance to ground to determined if I would blow a fuse on my ammeter (10A). Doing the math, I calculated less than 10 Amps. By isolating the draw to one cable, I know where the problem is not, I just don't know where it IS. You will probably see on modern cars and trucks that the positive battery cable is not a single heavy gauge wire that disappears somewhere under the hood. There is likely two or more wires connected right at the battery. You will also see negative ground return busses from various places around the vehicle. This is so not to rely on the chassis for a good ground. Vehicles have severals computers connected together and good solid connections are necessary for everything to function reliably. I think my problem has something to do with the slide-out rooms. For the slides to operate, the ignition switch has to be on and the parking brake set. I don't know, I'm open for any suggestions. Again, I was hoping that this was not an isolated case and someone has already experience this problem.
