bobndot
Aug 25, 2019Explorer III
The only things I would question is:
One thing I always suggest to new MH owners is to be aware of a lower rear overhang if you need to park it in your driveway. My rear hitch drags on my driveway apron once I load it up, which is all the time. When it was new and unloaded it just cleared it by 1/2". When I buy new tires I hope a larger tire will solve that. I have the room to move up 1" in diameter which will give me 1/2" in height which I hope will help.
MH's in general require a little more work to keep things quiet while enroute because you are riding inside the rv and not towing it. You don't hear pots n pans, A/C shrouds, stove tops and microwave trim-work rattling in fivers. Expect to be fussing with that stuff. I had to use plumbers tape on the screws for my interior AC plastic cover to keep them from loosening up. I used thin foam on the microwave trim and thicker foam on the stovetop.
I'm mentioning the last two things because its what I found when I went from trailers to MH's because we changed the way we use our rv's. We used trailers in campgrounds with hookups and smaller MH's for day trips and sleeping in non campground places. We now tend to go off the beat n path with the MH.
1. If you had to use that floorplan with the slides 'in' , would you be able to access the things you need ?
2. The queen bed is a folding queen which I do not think can be used unless the slide is deployed. That matters to some people that boondock overnight in rest areas or other places where they would like to remain more stealth.
38,782 PostsLatest Activity: Aug 11, 2021
