ron_dittmer
Oct 24, 2019Explorer III
carringb wrote:I was going to mention this but carringb beat me to it.
Nope. The E-series never got a power reduction. 1st thing to check is that nothing is obstructed. Some V10s a while back had a plastic flaps installed wrong, which would nearly completely obstruct the intake opening behind the grill.
Inspecting for it is very simple as follows.
Pop-off the black plastic oval air intake from the connection to the shroud located over the radiator, and look in the hole of the shroud. If you see a plastic flap obstruction, you must disconnect and lift the shroud, fold the black plastic flap in such a way that when you lower the shroud, it stays folded back.
Another item to inspect is the air filter itself. On rare occasion, the air filter comes apart and the domed plastic center piece is drawn to and blocks the air intake.
Both inspections take only a minute to do yourself, well worth the effort. It is inconvenient to get other people involved with issues you can easily take care of yourself. That is unless you have found the actual problem and have trouble dismounting and lifting the shroud. At the very least, you are knowledgeable when talking with a mechanic.
